Fuel injection
From Brisbane Qld
Iam think about geting ones of those Fuel injection manifolds
of the that guy on hear How much would it cost To get the rest of the
i would need If i dident want to send a Lot??? if possiable??
And what are the other things i need??
Posted on: 2012/11/3 3:56
Re: Fuel injection
Throttle body, injectors, fuel rail, fuel pump, fuel return, throttle position sensor, ecu, uprated ignition to start with. ON a budget you can scrounge the wreckers for parts.
I'm quite sure the manifold requires further machining from the cast so although the price is ok there is still alot to spend.
You may also need spellcheck haha just joking mate
Posted on: 2012/11/3 4:12
Re: Fuel injection
From Brisbane Qld
So would $1000 might be a good buget? to start with
Posted on: 2012/11/3 9:23
Re: Fuel injection
From Perth
If your buying new... triple that
If your asecond hand part user... you might get in under $1000
Posted on: 2012/11/3 10:25
Re: Fuel injection
if you have to get it tuned by someone else then no unless you got a mate who can do it for sweet fa, if your doing everything yourself then you could probably wing it
Posted on: 2012/11/3 10:57
www.datsun1000.com
Current Dato -
68 B20 ute
Previous Datos -
ca18det 1200 ute 180rwkw
Stocko 1200 wagon
Re: Fuel injection
From Brisbane Qld
Well the Question Is how much better would it run than a 32/36 Webber??
Is it realy worth spend the extra$$$
Posted on: 2012/11/3 19:30
Re: Fuel injection
If you have to ask that ... have you never owned or driven an EFI car? The difference to a carbureted vehicle is like night and day.
Posted on: 2012/11/3 21:15
Re: Fuel injection
From Brisbane Qld
Yes thats y i think it would be worth spending the extra$$$
Posted on: 2012/11/4 0:20
Re: Fuel injection
well i'd be looking at a budget of around 3.5g, maybe closer to 4 once it's tuned. thats pretty well everything new, i would be turbocharging it though as i can't see the point in spending all that money for such little power gain
Posted on: 2012/11/4 0:43
www.datsun1000.com
Current Dato -
68 B20 ute
Previous Datos -
Stocko 1200 wagon
Re: Fuel injection
You can use stock Datsun parts like 280Z injectors and S110 computer which requires NO tuning to run correctly on a A14.
Posted on: 2012/11/4 0:45
