A14 Adjustable Cam Gear
From Toowoomba
Does anyone know where I can buy an adjustable cam gear for an A14.
I want the type that doesn't require a new timing chain cover.
Think they are made by Rollermaster???
Posted on: 2012/11/6 8:27
Re: A14 Adjustable Cam Gear
Same cam gear is used by A12/A14/A15
Kameari sell one
Bprojects sell one, does not need new timing cover
Posted on: 2012/11/6 8:42
From Toowoomba
Anyone selling these in Australia?
I think paying $300 to land one in Aust is a bit steep!
Posted on: 2012/11/7 7:00
That's about what they all cost. Especially with that precision of adjustability. If it is too much then drill your own one and use the factory one.
Posted on: 2012/11/7 7:26
From Toowoomba
Hmm easier said then done...
Need template and then can be few degrees out
Posted on: 2012/11/7 7:35
Hmm, you might be a bit stuck.
Posted on: 2012/11/7 8:06
The Rollermaster ones are cheap, they are not precision, they just have two or three extra holes drilled, and you pick the one that seems best. You can do the same to a stock pulley.
Posted on: 2012/11/7 9:01
From sydney.nsw
rollmasters ones are multi keyway on crank gear.(7)keyways -6,-4,-2,0,+2,+4,+6
one std hole in cam gear.
no longer being made.
may find someone with old stock, if your lucky
Posted on: 2012/11/7 9:12
Edited by bige on 2012/11/7 10:18:11
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
They were a nominal +2, 0, and -2 degrees or something like that. Works well enough.
Posted on: 2012/11/7 10:13
