Gearbox.
From Trinidad and tobago
I have a 60a 4 speed gearbox an i dont have the bearing sleve but i got the fork with it,Could i use my 56L on to work it?
Posted on: 2012/11/9 22:19
'71 Four Door Sedan.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
Re: Gearbox.
No, only a 60 series will fit, and no I don't have a spare.
Posted on: 2012/11/10 1:35
Re: Gearbox.
Do you mean 60L 4-speed?
60-series and 56-series gearboxes use the same release bearing sleeves. But there are two different lengths.
Measure yours. Because 1200s can come with either size.
If you swap just the transmission from 56L to 60L, the two transmissions are different length. So just add the Engine Plate used with 60-series transmissions and it should make up the difference (assuming you are not running Engine Plate now).
Posted on: 2012/11/10 4:14
Re: Gearbox.
Yeah 60L.I have the short sleeve.So do i have to use the engine plate i got with the a15?
Posted on: 2012/11/10 23:48
Street Sleeper!
Re: Gearbox.
If you swap only the transmissions from 56L to 60L:
* If you A12 was not previously using an Engine Plate, add the Engine Plate used with 60-series transmissions.
* If your A12 was already using an Engine Plate, then remove it and use no Engine Plate.
All the engine plates are the same.
Posted on: 2012/11/11 1:43
Re: Gearbox.
Yeah i understand, what i mean is if i'm swaping 60l and a15 engine do i need the engine plate with the short bearing sleeve.
Posted on: 2012/11/11 14:50
Street Sleeper!
Re: Gearbox.
it depends ...
was the A15 & transmission working together before? Then don't change anything.
To be more exact, the engine does not matter, but the flywheel does. This combination should work:
* Any A-series engine (A12/A14/A15)
* Thick flywheel (30mm not 28mm)
* 60-series 4-speed or 5-speed
* Short release bearing sleeve
* Engine plate
Posted on: 2012/11/12 5:01
Re: Gearbox.
I baught the a15 alone it came with an engine plate donno how it was used before .Then i had a 56a to put on it.browsing the net i saw a guy that had a 60l for sale hearing how strong it was for the a15 so i baught it.I will be using the a12 flywheel.
Posted on: 2012/11/12 8:49
Street Sleeper!
Re: Gearbox.
I will suggest using removing engine plate if using thin 28mm flywheel. I think that will work.
Here all all the differences:
* Engine Plate is 3.5 mm thick
* A12 flywheel is 2mm thinner than A14/A15 flywheel
* Sleeves are 4.5mm difference
* Transmission seems to be 3.5mm difference (56L is longer)
Posted on: 2012/11/12 9:15
Re: Gearbox.
Thank you.
Posted on: 2012/11/12 9:18
Street Sleeper!
