Browsing this Thread:
1 Anonymous Users
Differences between a14 and a12? |
Just bought a 1978 ute with a14 in it. Had not been started in 4 years and ran first shot. Wondering on differences between a12 and a14 in regards to dizzy, water and fuel pumps etc. are they all the same? Motor is from a sunny. Also, is it relatively easy to replace heater hose?
Posted on: 2012/11/16 14:15
Re: Differences between a14 and a12? |
From Trinidad and tobago
Dizzy is a bit larger than the a12 has a 70mm cap,The water pump and fuel pump are all the same,but some have triangle fuel pump.
Posted on: 2012/11/16 19:15
'71 Four Door Sedan. A15 Engine + Lighten Flywheel. E15 Electronic Ignition 32/36 Weber EI Coil 4 into 2 into 1 Extractors 1 3/4 Exhaust Pipe Semi Flow Hotdog 60 series Gearbox H150 Diff.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
Registered Users Contentmaster Usermaster
More or less. Compared to 1970-1973 A12, an A14 has: * short water pump + less offset fan * slightly higher pressure fuel pump * distributor rotated differently with different plate
These three things make no difference is a swap, they connect the same way. They only make a difference if you try to put them on an A12.
Posted on: 2012/11/16 20:15
Edited by ddgonzal on 2012/11/18 3:21:15
Sweet. Thanks guys
Posted on: 2012/11/18 2:46
