1200 help !!!
Quite a regular
From gold coast, qld
Finally got my 1200 sorted and on the road. The only thins is when driving on even a slight hill or around corners the car stalls . It's only when you take your foot off the clutch the car goes completely quiet , it doesn't sound like its struggling for fuel . any help please thankss
Posted on: 2012/12/24 8:05
Re: 1200 help !!!
Sounds like the idle speed and idle mixture needs to be adjusted.
Adjust idle speed to 780 RPM, then adjust mixture to best lean. Then readjust to 750 rpm.
Posted on: 2012/12/24 8:21
Re: 1200 help !!!
Quite a regular
The car was driving fine a week ago tho ? It only does it when it warms up and then the chg light comes on in dash
Posted on: 2012/12/24 9:00
Re: 1200 help !!!
The charge light will come on whenever the engine dies.
So it was running fine a week ago, and now it is dying. What has changed in the last week?
Posted on: 2012/12/24 9:05
Re: 1200 help !!!
Quite a regular
No the chg light is always on now and the cars stalling , this past week I added a air filter housing but took that off and I removed a fuse from inside that's it
Posted on: 2012/12/24 9:09
Re: 1200 help !!!
First, fix the alternator -- and your engine problem may be gone.
You may have removed the fuse for the alternator.
If the alternator does not charge, then late-model 1200 ute choke doesn't work.
You may have knocked a vacuum hose loose when changing air filter.
Dash pot on late-1200 carburetor may be loose.
There can be many, many causes for a the engine stalling. Start with checking the items above.
Posted on: 2012/12/24 9:15
Re: 1200 help !!!
Quite a regular
At my wits end
Re: 1200 help !!!
Take it one step at a time -- that's what a mechanic does. Because there are many many causes to the symptom of "engine stalling".
Posted on: 2012/12/24 9:17
Re: 1200 help !!!
Quite a regular
Ok thanks heaps ill go through that this week ..its so frustrating it was fine a week ago and now it won't even idle thanks heaps tho really appreciate it
Posted on: 2012/12/24 9:18
Re: 1200 help !!!
Quite a regular
Where can I get an alyernator? And could the alternator fix the stalling? Sorry but how just so I know
Posted on: 2012/12/24 9:31
