oil presure isues !
From sunshine coast
hi all.
ive just finished rebuilding my old a12 and it appears i have no oil pressure.
before i put the motor together i striped down the oil pump and made sure it was in good condition.
do i need to prime it some how ? or will it pick up the oil if i start the engine?
ps. i did fill the oil pump prior to instal .
Posted on: 2013/1/6 4:43
73 1200 Ute
75 125 CR
84 250 CR
89 500 ktm
07 250 CR
vintage mx ....
Re: oil presure isues !
From Melbourne, Australia
yes you should prime the pump, did you fill the pump when you installed or just the filter?
you should tip some oil in the openings of the oil pump (pump removed from motor) and turn the drive until it starts pumping fluid
you should be easily able to pull it off the motor and do this even after it is all installed in the car
Posted on: 2013/1/6 4:56
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From sunshine coast
yeah i filed the pump and filter side .
guessing a bit ran out .. ill try the above tips . thanks heaps :)
Posted on: 2013/1/6 5:00
73 1200 Ute
75 125 CR
84 250 CR
89 500 ktm
07 250 CR
vintage mx ....
it will run out, but the key part is turning the pump over when you have it filled (held sideways), this way the oil gravity feeds into the actual pump section. once some oil is in there and the air has been forced out it is primed and should work fine.
If you have done this then i would make sure you haven't left the pick-up pipe out or something silly.
Posted on: 2013/1/6 5:14
1200 Coupe Rallycar
