Electric Choke Help
Not too shy to talk
Hey fellas. I decided to wire up my electric choke today (it was disconnected when I bought it).
Went down to Jaycar and got the required parts I needed. Found a switched 12v on the ignition harness and ran a wire through the hole where the manual choke goes.
I have a problem that I am not sure about and I will try and explain my best using pictures to help because I don't know the proper names for some things :p
So when cold and choke is fully on it should look like this, correct?
imgur
But by moving part where the spring attaches to;imgur
it only goes to here;imgur
and here it is at open (engine warm)
top: imgur
side: imgur
There is quite some play in this part; imgur
which allows me to close the choke all the way by hand even though the control arm for it doesn't move.
So my question is. Is something loose, broken or missing. Or is it meant to be how it is?
Advice much appreciated
Edit: Pics didn't work so I just added links sorry
Posted on: 2013/1/21 5:13
Re: Electric Choke Help
No, the choke should close 100%, not the 90% closed shown in this photo
Posted on: 2013/1/21 5:24
top: Open in new window
side: Open in new window
Posted on: 2013/1/21 5:26
Not too shy to talk
Thanks ddgonzal for fixing the pics. Just realised I tried linking the pics in album form rather than just the picture I wanted. My bad
Posted on: 2013/1/21 5:33
Not too shy to talk
Okay so I loosened this screw a few turns:
which allowed me to close it 100%
but as you can see in this second photo, it doesn't stay closed even though the little arm controlling it doesn't move
Whats up with that?
Posted on: 2013/1/21 5:48
Here's my Weber, an older model
Posted on: 2013/1/21 6:11
Not too shy to talk
This joint seems to be the problem. As you can see it has about a 30 degree play in it
Any ideas on how to fix it?
Posted on: 2013/1/21 6:26
Not too shy to talk
Fixed. The screw I adjusted before needed to be loosened even further as it was stopping the little arm that pushes from extending all the way
Posted on: 2013/1/21 6:40
