« 1 (2)
Re: Ca18 valve removal
From Goulburn NSW
Hi guys i have removed the valves,just used a g clamp and a bolt.Put the bolt on the side off the valve then tightened the clamp,worked a dream.
Posted on: 2013/1/27 3:56
Dodgey engineering of tools, your my hero, I use stuff like that all the time hahaha.
Posted on: 2013/1/27 4:24
G-Clamp (called C-Clamp here)
I'm surprised a valve spring compressor wouldn't work with your CA18 cylinder head. It's basically the same thing but with a forked end.
Posted on: 2013/1/27 5:21
From Goulburn NSW
Nah the usual valve remover wouldnt work as the springs are recessed down in the head about 1.5"like elemental_funk said.Glad that im not putting them back in.
Posted on: 2013/1/27 6:24
From Sydney NSW
Glad you got it sorted. I was going to say make sure you use safety glasses if you use a g clamp, i have a scar on my forehead from when it slipped off and the tool popped up.
Posted on: 2013/1/29 17:33
« 1 (2)
