A63 Gearbox
Not too shy to talk
Hello!!
Can i change A-motor bellhousing to box where are L-motor bellhousing? Are boxes otherwise same?
Posted on: 2013/1/29 15:37
Edited by Cherryx-1 on 2013/1/29 18:37:35
Re: A63 Gearbox
Are you asking about a 63-series gearbox?
The 63A is a 5-speed, and comes with different front case halves: either L-series or A-series front case. There are several mods that need to be done. Since the L-series version is more common and more available, no one converts A-series versions to L-series.
Posted on: 2013/1/29 20:10
Re: A63 Gearbox
From Selah, Washington
It can be done. although the input shaft is smaller on the A series and will require a special machined bushing.
Don't say no one does this David :) I am... anyway i am still uncertain as to the proper input shaft length. will know more soon
Posted on: 2013/1/30 1:29
Re: A63 Gearbox
You are converting an A-series box to use on an L-series engine?
Posted on: 2013/1/30 1:31
Re: A63 Gearbox
yes David, we have discussed this on Ratsun.. I have the A series gearbox and only the front section of the L series box.
Mike
Posted on: 2013/1/30 1:33
Re: A63 Gearbox
From Freo
heya Bluey, that just seems like a wrong thing to do,
L series easy to get hold of, A series 5 speeds, somewhat hard to find, and expensive..
Posted on: 2013/1/30 2:45
A15 PSI Project Motor
'72 CB750k,
Re: A63 Gearbox
Not too shy to talk
I have L-Motor A63 gearbox. But engine what i use is A-motor... And because A-motor a63 gearbox are rare to find...
Posted on: 2013/1/30 4:27
Re: A63 Gearbox
Blue max if you have a 63a bell housing an are trying to convert it to l series, I woul happily trade an l series bell house if not a full box for that 63a bell housing!!!!
Posted on: 2013/1/30 4:37
1200 Ute - Mild A12
1200 Ute - Donor Shell Sold
1200 Coupe - A14 EFI SC
Re: A63 Gearbox
I have two 63 boxes. plus the one still in my car. Datsuns are rare where Im at. You do realize I'm in the states?
Posted on: 2013/1/30 5:07
Re: A63 Gearbox
Yes, and in USA, the L-series 63A is more common than the A-series.
I was wrong in saying that no one converts A-series versions to L-series. There is one person doing so and several people who discussed it in the past.
Posted on: 2013/1/30 5:43
