What would you grab first...Parts swap Question???
From San Diego,California
What parts off of a 78 B210 would be worth swapping to a 72 1200...other than the motor or trans????
Maybe the brakes?
or the struts I'm not sure what to use I have a B210 at my disposal and want to know what to grab maybe the rear end ??Before it goes in the crusher!
I really don't want to dingle around when I go to get part's so..What would you guy's grab first??..that's the question?
Any help would be appreciated.
Posted on: 2013/2/8 1:25
Mahalo Victor
Re: What would you grab first...Parts swap Question???
* The electronic ignition distributor and icm box. It's a high-energy system.
* 13" wheels
* The diff center is stronger then the 1200 unit
* Not the struts. They are bigger and heavier on North American models.
See B210 Parts Donor for a list.
Posted on: 2013/2/8 1:52
From Trinidad and tobago
Front sway bar its thicker an the clamps.
Posted on: 2013/2/8 1:56
'71 Four Door Sedan.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
So take just the center out of the rear end? No axles.. just the guts? ok got it.
Is that a bolt on swap?
There are no more engine part's they got swapped into a 5o's Benz.
Posted on: 2013/2/8 2:00
Mahalo Victor
