(1) 2 3 »
A15tt problems analysis
From Melbourne, Australia
hmm, was just thinking, i cant get like 100% throttle as it cuts like theres not enough fuel,
but..
it's making 10psi boost and maybe trying to make more, so it's possible that it's trying to make more boost but there is not enough fuel/pressure to do so and therefore it is cutting
does this sound likely?, i think it could be my problem, which means i need to create a leak, probably just wont seal the lid on the carby box for now
Posted on: 2004/4/27 12:30
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: A15tt problems analysis
more air will only make it worse, you need more fuel otherwise it could lean ut too much and melt pistons or rings.... more air = more go...
sounds like not enough fuel
Posted on: 2004/4/27 12:34
From Christchurch. NZ
I take it that you ignition is up to the Task, if you wind the fuel pressure up and it is still the same. I'd suspect coil.
Posted on: 2004/4/27 12:37
problem is my pump is only rated to 14psi, so i cant get more pressure, although my gauge reads 16psi when i run it, im not sure if the pump is underratted or my gauge in-accurate
why the coil? as in it needs to be upgraded or isnt working properly???
Posted on: 2004/4/27 12:40
1200 Coupe Rallycar
ahh yes, it could be spark blow out from too much compression or boost, nay need to up the spark
there is no way a standard 1200 coil could handle the load of a turbo, you'll need at 25- 30KV for decent burning, thats the equivalent of a spark jumping about an inch gap, to run that you'll need modified points or eletronic ignition
Posted on: 2004/4/27 12:44
could reduce spark gap for temporary measure till more spark found
Posted on: 2004/4/27 12:46
dont tell me i need to change dizzy now!!!
just spent 180 getting it modified so im guessing they considered it up to the job as is, how do i go about finding the right coil?
what spark gap ya reckon?
Posted on: 2004/4/27 12:48
1200 Coupe Rallycar
just get a nissan one off an efi engine, you can buy kits from dick smiths to upgrade your points. plug gap 1.1mm BPR6EY-11
edit: use the above plug after new ignition, otherwise set currnet plug to 0.5mm and dont run 100% throttle
Posted on: 2004/4/27 12:50
dont need to mod dizy, just better coil, cnay you set two uo, one to two cyl and one to the others? just wondering?
spark gap, what is it now, should not be 0,8mm more like 0.6, try it as liitle at a time
Posted on: 2004/4/27 12:54
(1) 2 3 »
