Browsing this Thread:
1 Anonymous Users
Nissan Part numbers needed |
From Seattle ,WA.
I'm having a difficult time locating the OE numbers for a 1980 A15 engine complete gasket set, individual head, pan, timing cover gaskets - anyone have these?
David??
Thanks, Evan
Posted on: 2013/3/15 16:40
Re: Nissan Part numbers needed |
Registered Users Contentmaster Usermaster
Same as A14. There are no unique A15 head parts.
$136 USD list price Head Set 11042-H9527 KIT-VALVE REGRIND A14,A15(CAN) - 2 11042-H9526 11042-H9526 KIT-VALVE REGRIND A14,A15(CAN) 0880- 2 11042-H7226 11042-H7226 KIT-VALVE REGRIND A14,A15(CAN) 0879-0780 0 11042-H8927 KIT-VALVE REGRIND A14,A15(USA) - 2 11042-H9826 11042-H9826 KIT-VALVE REGRIND A14,A15(USA) 0880- 0 11042-M6726 11042-H9527 KIT-VALVE REGRIND A14,A15(CAN) - 2 11042-H9526 11042-H9527 KIT-VALVE REGRIND A14,A15 CAL A14 FED(KFU) A14 CAN -0779 2 11042-H9526 11042-H8927 KIT-VALVE REGRIND A14,A15(USA) 2 11042-H9826 11042-H9527 KIT-VALVE REGRIND A14,A15 CAL A14 FED(KFU) A14 CAN -0779 2 11042-H9526 11042-H7227 KIT-VALVE REGRIND A14,A15 FED (EXC KFU) -0779 2 11042-H7225 11042-H7227 KIT-VALVE REGRIND A14,A15 FED (EXC KFU) -0779 2 11042-H7225
Posted on: 2013/3/15 17:23
individual gaskets:
11044-H7201 GASKET-CYLINDER HEAD A14,A15 -0780 [1979 & 1980 model years] 11132-H5025 GASKET SET-OIL PAN A14,A15 13044-H1000 GASKET-TIMING CHAIN COVER A14,A15
Posted on: 2013/3/15 17:34
From Seattle ,WA.
thanks. It must be slightly different from the A12 head then as I seem to remember the two gaskets not interchanging, oil pan gasket isn't the same either.
Posted on: 2013/3/16 0:49
Oil pan gasket is the same -- H50 is an A12 part number.
Head gasket from Nissan differs: 73mm bore for A12, 76mm bore for A14/A15. And yet Nissan used three different head gaskets for A15, some supposedly non-interchangeable. Aftermarket gasket is ONE gasket for all A14 & A15 engines.
Posted on: 2013/3/16 5:06
From Seattle ,WA.
I distinctly remember the oil pan gasket being different from the A12, I have like 3 NOS form the 70's or 80's packages of Datsun pan gaskets & they're slightly different. If I remember correctly they have a slightly different curve to them...... I'll buy an A15 gasket & post up some pic's. I remember this cuz I couldn't use them on the last build.
Posted on: 2013/3/16 5:10
A15 uses an A12 oil pan gasket. That said, there might be a difference between early and late A12 oil pan gaskets.
Posted on: 2013/3/16 5:24
From Seattle ,WA.
thats a good point, I'll post some pic's when I have the pan off w/the old & new gaskets
Posted on: 2013/3/16 17:20
