A15 Electronic Ignition conversion.
From Trinidad and tobago
Ok.so i have my a15 points dizzy and a e15 dizzy out of a n12 pulsar.I have read alot in the tech wiki an i will like anyones info on how to do this step by step so i can use it in my feshly build a15 that i have never started an i want to have a little street rocket soon
So here i have the a15 dizzy.
Here i have the a15 and e15 dizzy side by side.
Measuring the shaft here is my problem how to get the shaft off the a15 and on to the e15 one.
Different lenghts.
If anyone has any inf please fill me in.
Cheers Darren.
Posted on: 2013/3/19 0:31
'71 Four Door Sedan.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
Re: A15 Electronic Ignition conversion.
No need to change shafts.
Just put the gear one on E15 shaft. Drill a hole for the roll-pin.
Step-by-step instructions are at http://datsun1200.com/modules/mediawi ... utor_Swap#Gear_Changeover
Posted on: 2013/3/19 1:16
do i need to carry it in a machine shop?
Posted on: 2013/3/19 1:32
Street Sleeper!
You can use a drill press or maybe a held-held drill?
Posted on: 2013/3/19 1:38
what about the sr20 distributor in to a15?easy conversion?
Posted on: 2013/3/19 23:36
Street Sleeper!
Not as easy as the E15 conversion.
Posted on: 2013/3/20 0:16
Ok Mr david i went an did the gear change over an got it back in about 30 mins
Posted on: 2013/4/4 1:07
Street Sleeper!
Very good. Static time it to 5 degrees BTDC and enjoy. You may be able to advance the timing some (until it pings then back it off).
Posted on: 2013/4/4 1:40
yes thanks,heres a pic of it thanks for your help
Posted on: 2013/4/4 2:09
Street Sleeper!
how are you going to bolt it down?
make a bracket?
or, grind the distributor housing to fit the A14/A15 plate?
or just use vice-grips?
Posted on: 2013/4/4 2:55
