Carby problms
From Kelmscott Western Australia
As wat the title says
My ute was running fine then i got to a set of traffic lights stalled fuel pissing out of the carby got it home by the rac strip it down cleaned it put the kit through it with new needle for float etc etc start it ran fine took it around the block got home left it for 5 or so minutes then it flooded again What is your opinion people float level is fine anf im running a electric fuel pump
Posted on: 2013/4/1 6:33
Re: Carby problms
Incorrect fuel pressure. It should be no more than 3.2 pounds and no less than 2.8 pounds.
Posted on: 2013/4/1 6:48
Re: Carby problms
From Perth WA AUS
What psi does the pump put out? Sounds like you need a reg'
Posted on: 2013/4/1 7:09
Datsun 1200 2Dr sedan.
Re: Carby problms
On the packet its 4-7 psi its pulling i got the car goin again but when the carby starts to overflow the pump makes a racket its a new pump only been on the car for a week
Posted on: 2013/4/1 7:14
Re: Carby problms
From Perth WA AUS
They normally make noise when they priming or starved of fuel, definately get a regulator fitted after the pump (non efi) and check the location of the mounted pump is suitable for correct operation.
Posted on: 2013/4/1 7:19
Re: Carby problms
Im just thinking of puting a kit through my mechanical pump just to see how it goes try the car again just flooding still :/ when i 1st put the pump in the float was a bit higher
Posted on: 2013/4/1 7:42
Re: Carby problms
Posted on: 2013/4/1 7:51
Re: Carby problms
From Perth WA AUS
That may be a good idea, stock pumps are fine.
Posted on: 2013/4/1 10:36
Re: Carby problms
Its just strange how this just happen esspecially when i was goin on yesterdays run im just thinkin it is just the pump over pressurising cause i took the top off again on my carby and got a little container of fuel to see where the float sits sat where the half mark is on it
Posted on: 2013/4/1 10:50
Re: Carby problms
From Perth WA AUS
I am using a similar electric pump with dual carbies and a fuel regulator is required and must be set to around 3psi of pressure.
It does seem strange that it runs for quite a while and then floods though,
many people on this site know much more than me about carbs though, good luck.
Posted on: 2013/4/1 11:02
