« 1 2 3 (4) 5 »
Re: silvia brakes on 120y strut
For 910 brake usage, see 910 Brakes
Posted on: 2013/4/13 5:33
From Trinidad and tobago
thanks
Posted on: 2013/4/13 5:49
'71 Four Door Sedan.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
How much you sell the brackets for Benny?
and do you need to modify the 120y hubs to fit the 250mm discs?
Posted on: 2013/5/2 23:22
From Springwood NSW, Formerly Tas.
So the s13 studs will fit in the 120y hub?
i asked our local parts place for dimensions and he said the silvia ones were 14.3mm knurl and the 120y ones were 12.7
Posted on: 2013/5/8 5:14
1978 120y Coupe.
120Y studs have 13.0 mm knurl with 10mm shoulder
S13 studs have 12.83 mm knurl with 14mm shoulder
S13 studs will fit the 120Y hub, go in and center properly. They are approximately 13mm longer, which is needed because the rotor face goes over the hub.
Posted on: 2013/5/8 6:09
yeah cool, the same brand also makes longer standard ones so i might just buy one of each and see what they look like.
i'll post pics when i've finished the conversion.
Thanks
Posted on: 2013/5/8 6:40
1978 120y Coupe.
Not too shy to talk
What brake booster/master cylinder are you going to use with the s13 brakes...
Posted on: 2013/5/8 8:36
From A-TOWN
im using a brand new 120Y master, no booster. Boosters are gay.
Posted on: 2013/5/8 8:44
Not too shy to talk
How do you guys rate the 250mm discs for track work?
I want to stick with 13's for my sunny excellent replica but from what I can find they ran Girling 4 spot calipers which I am guessing will be pretty much unobtainable.
Posted on: 2013/5/8 10:17
I reckon I'll just use the 120y M/C and booster.
Posted on: 2013/5/8 13:13
1978 120y Coupe.
« 1 2 3 (4) 5 »
