Re: 1200 ute + L18 + 5speed = Daily Drive
From Armidale N.S.W
If your using photobucket copy and paste the link that has IMG at the beginning and end then change the IMG to img (upper case to lower case).
Otherwise if you want to copy from your computer when you hit reply below the box you type in you will see Choose File. Hit that then find the file ( i usually put them in a specific folder on my desktop).
When you choose the file then hit upload to the right of Choose file (file must be less than 200kb). Repeat that process till your done then hit Submit as usual.
P.S dont tick the boxes of uploaded files it will delete them. Cheers hope that helps i can talk you through an example over the phone if your stuck. Cheers Andrew
Posted on: 2013/4/17 9:35
73 1200 wagon SOLD
Subject Poster Date
     1200 ute + L18 + 5speed = Daily Drive leddo 2013/2/20 10:32
       Re: 1200 ute + L18 + 5speed = Daily Drive ANGE 2013/2/20 10:37
         Re: 1200 ute + L18 + 5speed = Daily Drive Anonymous 2013/2/20 10:41
       Re: 1200 ute + L18 + 5speed = Daily Drive DatsAndy 2013/2/20 10:42
         Re: 1200 ute + L18 + 5speed = Daily Drive PIGDOG 2013/2/20 11:22
           Re: 1200 ute + L18 + 5speed = Daily Drive a12grunt 2013/2/20 12:19
       Re: 1200 ute + L18 + 5speed = Daily Drive b310gx 2013/2/21 8:52
         Re: 1200 ute + L18 + 5speed = Daily Drive leddo 2013/2/24 11:03
           Re: 1200 ute + L18 + 5speed = Daily Drive Anonymous 2013/2/24 11:14
             Re: 1200 ute + L18 + 5speed = Daily Drive Anonymous 2013/2/24 20:30
       Re: 1200 ute + L18 + 5speed = Daily Drive b310gx 2013/2/25 9:22
         Re: 1200 ute + L18 + 5speed = Daily Drive leddo 2013/2/27 0:59
           Re: 1200 ute + L18 + 5speed = Daily Drive Anonymous 2013/2/27 1:03
             Re: 1200 ute + L18 + 5speed = Daily Drive ddgonzal 2013/2/27 3:50
       Re: 1200 ute + L18 + 5speed = Daily Drive b310gx 2013/2/27 6:45
       Re: 1200 ute + L18 + 5speed = Daily Drive leddo 2013/2/27 11:43
       Re: 1200 ute + L18 + 5speed = Daily Drive leddo 2013/3/1 1:07
       Re: 1200 ute + L18 + 5speed = Daily Drive leddo 2013/4/16 4:19
         Re: 1200 ute + L18 + 5speed = Daily Drive Anonymous 2013/4/16 9:14
           Re: 1200 ute + L18 + 5speed = Daily Drive leddo 2013/4/16 9:37
       Re: 1200 ute + L18 + 5speed = Daily Drive b310gx 2013/4/16 10:58
       Re: 1200 ute + L18 + 5speed = Daily Drive simmos_datto 2013/4/16 16:02
       Re: 1200 ute + L18 + 5speed = Daily Drive robbie 2013/4/16 22:24
       Re: 1200 ute + L18 + 5speed = Daily Drive leddo 2013/4/17 9:26
       Re: 1200 ute + L18 + 5speed = Daily Drive DatsAndy 2013/4/17 9:35
       Re: 1200 ute + L18 + 5speed = Daily Drive leddo 2013/4/17 10:57
         Re: 1200 ute + L18 + 5speed = Daily Drive robbie 2013/4/17 12:21
       Re: 1200 ute + L18 + 5speed = Daily Drive datsunbeginner 2013/4/17 12:37
       Re: 1200 ute + L18 + 5speed = Daily Drive leddo 2013/4/17 13:54
         Re: 1200 ute + L18 + 5speed = Daily Drive Anonymous 2013/4/17 14:05
       Re: 1200 ute + L18 + 5speed = Daily Drive leddo 2013/5/6 5:22
         Re: 1200 ute + L18 + 5speed = Daily Drive ddgonzal 2013/5/6 5:53
         Re: 1200 ute + L18 + 5speed = Daily Drive L18_B110 2013/6/6 0:30
           Re: 1200 ute + L18 + 5speed = Daily Drive leddo 2013/6/6 2:24
       Re: 1200 ute + L18 + 5speed = Daily Drive leddo 2013/6/5 14:03
       Re: 1200 ute + L18 + 5speed = Daily Drive leddo 2013/6/17 4:31
         Re: 1200 ute + L18 + 5speed = Daily Drive Anonymous 2013/6/17 4:51
       Re: 1200 ute + L18 + 5speed = Daily Drive old-tin 2013/6/17 6:10
       Re: 1200 ute + L18 + 5speed = Daily Drive leddo 2013/6/17 7:21
         Re: 1200 ute + L18 + 5speed = Daily Drive armiee 2013/6/17 10:09
       Re: 1200 ute + L18 + 5speed = Daily Drive Dundee1000 2013/6/18 0:20
       Re: 1200 ute + L18 + 5speed = Daily Drive leddo 2013/7/1 13:23
         Re: 1200 ute + L18 + 5speed = Daily Drive ddgonzal 2013/7/1 16:41
       Re: 1200 ute + L18 + 5speed = Daily Drive leddo 2013/11/1 0:48
