Re: Distributor Vacuum Issues
Pertronix kit does not affect the vacuum advance in any way. It is not connected to it.
If the vacuum advance is leaking, then just plug the hose -- it will run OK again after that. There is a small low-throttle-opening advantage if you then obtain a new vacuum advance. But the engine will run pretty good with the hose plugged, it will have 100% of the power at mid-throttle to full throttle with the hose plugged.
Posted on: 2013/5/1 2:53
Subject Poster Date
     Distributor Vacuum Issues toonenbmx 2013/4/30 10:32
       Re: Distributor Vacuum Issues dattodude 2013/4/30 11:08
       Re: Distributor Vacuum Issues toonenbmx 2013/4/30 22:42
         Re: Distributor Vacuum Issues ddgonzal 2013/5/1 2:53
           Re: Distributor Vacuum Issues toonenbmx 2013/5/1 3:02
             Re: Distributor Vacuum Issues ddgonzal 2013/5/1 3:51
             Re: Distributor Vacuum Issues toonenbmx 2013/5/2 2:54
               Re: Distributor Vacuum Issues ddgonzal 2013/5/2 4:50
