weber
From Trinidad and tobago
I installed a 32/36 weber on an a15 i put on the stock cabby linkage but i am not getting full throttle why is that? does the accelerator cable needs to be shorter how am i doing that?
Posted on: 2013/5/13 1:10
Edited by darrenwilson on 2013/5/13 2:27:43
'71 Four Door Sedan.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
Re: Dont leave me in the dark
The cable does not need to be shorter. But it must be fastened correctly.
First, take the cable off. Can you then open the throttle by hand all the way open? If not there is a problem with the carburtor. For example, the linkage could be physically touching some part of the engine which blocks it.
Are you using this type of throttle linkage?
Posted on: 2013/5/13 1:54
Yes i Can open the throttle by hand all the way open.
I dont have and bracket all i have is stock hitachi 'wheel'
Here i saw some 1used thee stock holder to mount the cable
What else is needed?
jpg  13914_4dff3abdeb378.jpg (90.08 KB)
12526_51903cf803a60.jpg 600X450 px
Posted on: 2013/5/13 2:03
Street Sleeper!
Re: weber
That is the RHD Hitachi throttle cable bracket/clamp.
To use the bracket like that, you must adjust the cable. With the throttle closed all the way, there should be almost no play in the cable. If there is too much play, use spacers or otherwise take up the play.
If there is a lot of play, you can go to the pedal inside the car and wrap the extra wire around the pedal shaft once.
For a little play, cut a piece of rubber hose, slit it down the middle and put between the clamp and the cable.
You can buy the genuine Weber bracket, or make one similar:
Posted on: 2013/5/13 3:16
Re: weber
I am not getting full throtte why is that?
Posted on: 2013/5/13 23:59
Street Sleeper!
Re: weber
If the throttle opens all the way by hand, but not with the pedal, it is almost for sure that the cable is not adjusted correctly.
If there is any play in the cable, then it will not open all the way.
Posted on: 2013/5/14 2:19
