A15 question
Not too shy to talk
From Tassie
G'day all,
Is the A15 short block a good engine to put in a 1971 1200 ute?
Any dangers/drawbacks to look out for?
After reading the info in the tech wiki section about engine upgrades, I am aware of the type of modifications needed and also about the diff issues.
Why was there short variations?
Any help would be great,
Mat
Posted on: 2013/5/25 20:02
Re: A15 question
I don't think there was a short variation. Short Motor and long motor is sometimes a terminology used to describe how much of the complete engine package is for sale. A short motor can be just the block crank and rotating components, whereas a long motor can include the cylinder head and a few ancillaries if not all.
That's my understanding of it anyway.
Your ute diff will be plenty strong for the A15 no need to modify your diff. The ute comes with the H165 diff.
Posted on: 2013/5/25 21:43
Re: A15 question
From Trinidad and tobago
All a15 blocks are the same stroke.Good choice for a ute
If you get a 56a gearbox to go with itNo problems, but a 60 series gearbox will be the right torque an strong enough for the a15 no need to change prop shaft.
Posted on: 2013/5/26 3:00
'71 Four Door Sedan.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
Re: A15 question
Right you are:
Long block is assembled block AND head
Short block is assembled block WITHOUT head
Posted on: 2013/5/26 4:14
Re: A15 question
Not too shy to talk
From Tassie
Thanks for clearing that up, good info.
My ute has the 56A
So what's the best head to get $$ wise?
or just stick with what I've got on the A12?
Cheers,
Mat
Posted on: 2013/5/27 3:41
Re: A15 question
A12 head is good on an A15 for about 65 HP @ 4800 RPM
H89 head is good for about 80 HP @ 6000 RPM
Posted on: 2013/5/27 3:44
Re: A15 question
If you are going A15 you are best to use the oval port engine head with the stamp H89 as suggested by DD.
Posted on: 2013/5/28 1:15
