Urgent Help.
From Trinidad and tobago
Hi folks Needs urgent help.I have installed e15 dizzy [No points].wires are 1 to positive and one to the negative of coil when using points less ignition do you need to bypass the resister? .Thats ok!But the serious part is that i dont kno where wires go.Keeping me back from firing up my motor.
Stands as this currently what wires to use and what not to is my main prob.
A PIC of coil.
All help would be greatly apriciated an help me to start up my engine.
Posted on: 2013/5/26 4:01
'71 Four Door Sedan.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
Re: Urgent Help.
Wire the new Coil the same way as the old coil:
START wire to COIL+
IGN wire to ballast resistor on the new coil
The no-points distributor if it has BLUE and BLACK/WHITE wires will go the COIL+ (BW) and COIL- (BLUE) terminals.
If the no-points distributor has RED & GREEN wires then it needs an external electronic module.
Posted on: 2013/5/26 4:12
Re: Urgent Help.
Ok thanks.
Its The no-points distributor if it has BLUE and BLACK/WHITE wires will go the COIL+ (BW) and COIL- (BLUE) terminals.Got that right,But i asked some 1 an they told me to remove resistor.
So IGN wire to ballast resistor on the new coil what part of the resistor does the wire go?What goes to the battery??
Posted on: 2013/5/26 4:26
Street Sleeper!
Re: Urgent Help.
Do not remove the resistor UNLESS the coil is designed for use with no resistor.
Posted on: 2013/5/26 19:39
Re: Urgent Help.
I dont know if the coil was designed to use with out resistor.
Posted on: 2013/5/27 12:53
Street Sleeper!
Re: Urgent Help.
What's the part number on the coil? Brand etc. more information and we can,see if we can work this out.
On my 1200 I think the wires were just bridged together when removing the resistor.
My stanza, well I had to put terminals on each of the wires and hook up to the positive, of the coil.
Posted on: 2013/5/27 16:42
Re: Urgent Help.
Since the coil appears to have a resistor bolted to it, it almost for sure REQUIRES the resistor.
For the factory 1200 wire colors for Start and IGN wires, see Coil Wiring.
Posted on: 2013/5/27 18:56
