What shocks
Not too shy to talk
Hey all, I need a new pair of front shocks for my 1200 coupe.
I was looking at the 8704 Pedders Cartridge which is about $300 for the pair but I want to know if there are any better replacements?
Any suggestions would be great
Thanks
Posted on: 2013/7/14 7:08
Re: What shocks
Koni on eBay for same price in Australia. Kyb too
Posted on: 2013/7/14 8:51
Re: What shocks
From Brisbane Qld
I spent a lot on my suspension on my B310 good king springs and great gas shocks on the back
But the front is still higher than the back. And I made a mistake with the strut oil insert's
But I had two different length strut but we solved it with different nuts to hold it down.
Now the problem is its still really bouncy? what could I do with out changing the hole struts
Posted on: 2013/7/14 14:02
Re: What shocks
Not too shy to talk
Any difference between the brands or all they all much the same? Does price indicate quality, or are any good enough?
Posted on: 2013/7/15 5:27
Re: What shocks
To a degree price= quality. I would suggest the biggest gain someone might get, would be if you currently had totally worn out inserts and replaced them with any new/working ones. There is a jump again with different brands, but it'll be a smaller gain than the gain from going to stuffed ones to new ones.
the other thing is that to get it 'right' - even with adjustables - you really need the shocks to be put on a shock dyno and tested throughout their range of adjustment (if they in fact are adjustable) I've read an article or three where they did such tests and there was a significant difference from one to the other, out of what should have been a matching pair. And then sometimes the adjustment to make rebound stiffer (for example) made it softer, or paradoxically altered bump stiffness without affecting rebound to a certain degree.
So to get it optimal, you need to test em, find out which settings actually achieve what, and then try them and based on results adjust (if there is scope to do so) to get em fine tuned.
But again, the biggest gain will be replacing shagged ones with working ones.
It's also quite possible that the spring rate is too soft. If it has std springs, you can take that as a safe bet. For a streeter you'd tend to want double (or a little more) the factory spring rate. I've brought up in the past you can use the front springs out of a td gemini (you can use later ones, which are variable rate, but I prefer linear - just one of my idiosynchrasies/driving style etc). because the gemini has wishbone front, and the spring sits inward from the ball joint (whereas a strut front, it is right out there on top of it) - the control arm gets more leverage on the spring, and the spring has less leverage on the control arm, so the gemini springs are a lot higher rate. You'll still have to cut a couple of coils off the gemini springs to get the ride height down to a normal level, which then has the issue of not being captive if you jack the car up and the suspension droops all the way down. The solution here is to get shorter strut insterts. There is a page on the wiki about various part numbers. I have gotten a set but don't have the part # in front of me, I'll probably have to dig it up over the weekend). There's also a japanese performance shop type website that lists off teh shelf shortened strut inserts for the early 45mm strut tubes. I don't know if they are (like mine) off another car and happen to fit, or if they got 1200 inserts and machined the pushrod and re-threaded it, to remove some length.
http://www.datsun1200.asia/category/select/cid/318/pid/8889
Posted on: 2013/7/15 10:08
John McKenzie
Re: What shocks
New shocks can cause bounce. The genuine Nissan shocks are carefully tuned for the stock suspension and do not cause bouncing. Most all aftermarket shocks are more firmly valved and cause a harder ride. If you can get adjustable units that will work too.
Posted on: 2013/7/15 21:03
