« 1 ... 3 4 5 (6) 7 8 9 ... 57 »
Re: Datsunbeginner becomes an expert - Vanilla ute build
Stupid me. I also forgot to finish installing my Maddat steering box brace. Now I can't drill the holes in the inner guard for the bolts.
Posted on: 2013/7/23 11:30
Bummer that the previous guy cut off the gearbox mounts. Here are some pictures of my jerry rig gearbox. Also the tailshaft is 1 inch too long for the 60a gearbox. Still not sure what car the diff and tailshaft are from.
jpg  P1010490.jpg (147.71 KB)
13419_51ee65e125240.jpg 800X533 px
jpg  P1010491.jpg (149.67 KB)
13419_51ee65e8e2ea4.jpg 800X533 px
jpg  P1010492.jpg (129.68 KB)
13419_51ee65f3da8f3.jpg 800X533 px
jpg  P1010497.jpg (151.57 KB)
13419_51ee65fa4e455.jpg 800X533 px
Posted on: 2013/7/23 12:16
You can see I changed from rope to wire and stuffed a rag in the rear of the gearbox to keep the leftover gear oil spilling out. Some people have suggested using a spare yoke from a tailshaft to plug the hole, great idea for future reference.
Posted on: 2013/7/23 12:18
gives you perfect chance to make new and better angled gearbox mounts and sit the engine lower with lower engine mounts maybe
Posted on: 2013/7/23 12:45
Thanks for the hint sexy Is that supposed to increase performance somehow?
Posted on: 2013/7/23 14:33
Next was new steering.
Here is a picture of the steering before I installed replacement parts.
jpg  P1010452.jpg (186.91 KB)
13419_51ee896aab196.jpg 800X533 px
Posted on: 2013/7/23 14:47
That ball joint took me hours to remove.
Here is a picture after. New inner tie rods, outer tie rods, ball joint, radius rod bushings, draglink, idler arm. No new bushings for sway bar yet though. I don't know how important they are to replace but I will do them later. Also did not replace the lower control arm bushings. Again is it okay to reuse the pins and bolts? The tie rods, idler, draglink, and ball joint came will all NEW hardware. Only thing I replaced on my own was the sway bar mounting bolts which I bought High Tensile 8.8 rated bolts for. The rest is the standard bolts/nuts.
jpg  P1010473.jpg (168.87 KB)
13419_51ee8a4d1b56f.jpg 800X533 px
Posted on: 2013/7/23 14:51
I am hoping that I installed all this gear properly or else I'm gonna end up off the road balls deep in a cornfield somewhere, awwww shooot.
No seriously. I did not follow the workshop manual's torque settings because I don't own a torque wrench.
And I've been told you need a front alignment done when you do new steering.
Anything else to double check?
jpg  P1010474.jpg (165.24 KB)
13419_51ee8c5de25e1.jpg 800X533 px
jpg  P1010475.jpg (165.55 KB)
13419_51ee8c6732ff0.jpg 800X533 px
jpg  P1010476.jpg (142.84 KB)
13419_51ee8c764a513.jpg 800X533 px
jpg  P1010477.jpg (113.83 KB)
13419_51ee8c85df32e.jpg 800X533 px
jpg  P1010479.jpg (146.41 KB)
13419_51ee8c95dba2c.jpg 800X533 px
jpg  P1010481.jpg (138.50 KB)
13419_51ee8cae06fb7.jpg 800X533 px
Posted on: 2013/7/23 15:01
From Trinidad and tobago
Good stuff!!
Check out my thred when you get a chance.
Posted on: 2013/7/24 1:55
'71 Four Door Sedan.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
Thanks d.w. I've seen your build thread as well. Very nice work.
Posted on: 2013/7/24 4:17
