Need Pictures of the Heat Shield
From South Africa
Hey Gentlemen,
Does anyone have 2 or 3 good pictures of the heat shield behind the carbs? I'm having one lazer-cut out of 2mm stainless steel. Mine literally tore and it seems as if someone punished it with a grinder.
I've searched quite a bit, so my keywording must be off. I just need a shove in the right direction please.
Thanks for your time.
Posted on: 2013/8/7 8:54
Re: Need Pictures of the Heat Shield
From Gold Coast,QLD.
Is this the one you want,GX carbs/heat shield?
jpg  1-20130807_181526.jpg (135.33 KB)
436_520205f096734.jpg 640X480 px
jpg  2-20130807_181714.jpg (99.45 KB)
436_520206044214b.jpg 640X436 px
jpg  3-20130807_181542.jpg (120.91 KB)
436_520206108cd98.jpg 640X480 px
jpg  4-20130807_181914.jpg (130.84 KB)
436_5202061abfc3b.jpg 640X480 px
Posted on: 2013/8/7 9:34
SLICK & SMALL IS THE WAY TO HAUL!!!!
From South Africa
That's the one. Thanks a stack! I notice mine doesn't have those 2 fingers standing up on the upper corners. It seems someone bent them and cut them off. what are they for?
Also seems like the gap in the middle was cut deeper towards the bottom...skew too.
jpg  IMG02215-20130807-1042.jpg (19.56 KB)
17010_5202146241986.jpg 320X240 px
Posted on: 2013/8/7 10:10
Edited by Liebonhardus on 2013/8/7 10:33:22
They shield the twin fuel lines coming to each carb!!
Posted on: 2013/8/7 10:44
From South Africa
The other picture...
jpg  IMG02216-20130807-1043.jpg (20.17 KB)
17010_52021a9b2178d.jpg 320X240 px
Posted on: 2013/8/7 10:59
From South Africa
Apologies, this is my first Datsun restoration. So I'm not completely competent. Having said that, how do those guard the fuel lines? Mine just rain straight from the steel line next to the rocker cover.
Posted on: 2013/8/7 11:12
They shield the lower fuel bowl lines. Shield it from the exhaust manifold heat.
Posted on: 2013/8/8 3:00
From South Africa
Thanks Guys.
I think I'm getting the hold of how it works. I'm having the manifolds sandblasted and powder coated today, so when the get back, I'll take one last look before I have anything new cut.
Thanks Again
Posted on: 2013/8/8 6:33
