Browsing this Thread:
1 Anonymous Users
Slow pickup |
From Trinidad and tobago
Ok so i serviced my 32/36 weber an put it back on,before i drove i replaced a distributor cap but didn't drive since a put back on the caburetor now the car is a bit lazy in 2nd and 3rd gears any one had issues like this before an has any pointers? plugs,leads or maybe timing?
Posted on: 2013/8/5 15:42
'71 Four Door Sedan. A15 Engine + Lighten Flywheel. E15 Electronic Ignition 32/36 Weber EI Coil 4 into 2 into 1 Extractors 1 3/4 Exhaust Pipe Semi Flow Hotdog 60 series Gearbox H150 Diff.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
Re: Slow pickup |
Any tips fellas?
Posted on: 2013/8/6 23:26
Street Sleeper!
Re: Slow pickup |
Registered Users Contentmaster Usermaster
I would suspect the carburetor, since it was just changed. Servicing carburetorss often ends up with problems. Maybe the float level changed, maybe a jet is loose.
Posted on: 2013/8/8 3:07
