« 1 (2)
Re: Help!
From Castro Valley,CA USA
"Thanks it all started when i was driving the light started flashing slowly then later now its staying on,i checked the fan belt and its tight"
I've had this happen three times as you have described.
Each time found the brushes worn down as DD shows.
Posted on: 2013/8/16 17:06
Re: Help!
From Trinidad and tobago
Ok sinario is took alternator to a electrician came back an put it on an drive he told me drive an let the battery build back up .when driving for the whole day went to start back and only getting a click click battery was dead is it possible the alternator is nor working?
Posted on: 2013/8/21 19:05
'71 Four Door Sedan.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
Re: Help!
Very very common cause of this is a battery cable connection that is not spotless. See http://datsun1200.com/modules/mediawi ... title=Battery_Maintenance
battery was dead
Even a good battery with bad connections will appear dead. It will also start right up with jumper cables. Cleaning is the first thing to try when these symptoms occur.
If the alternator is charging (13.5 or higher volts) for at least 15 minutes and the cables are clean, and this still occurs then the battery is most likely worn out. Replace the battery.
Posted on: 2013/8/21 22:21
Re: Help!
I'm going to carry the alternator by another electician tomorrow to get it checked on again the guy before had no clue what he did an put me in a bad situation yesterday. So i'll get back the alternator and put it back on and get the charging rates an put it back up for you DD. Battery terminals are all good and ground straps are in good contact and clean.
Posted on: 2013/8/22 4:30
Street Sleeper!
Re: Help!
Okay so i got back my alternator put it up and got it running.checked the charging rates an it was spot on but still not charging.Ran to the wreckers and picked up a used regulator box and hooked it up now every thing is running perfect so i just wanted to let you know what was the end result,a bad regulator box...
Posted on: 2013/8/26 2:54
Street Sleeper!
Re: Help!
The thing the Regulator does is regulate the Voltage to somewhere between 13.5 to 15.5 volts. So that's why it is most important to check the voltage. Nothing else really matters.
Posted on: 2013/8/26 4:23
« 1 (2)
