ca18det and manual box datsun 1600/120y kit
here i have a Complete ca18det and manual box that i was going to put into my 120y but have decided i need to invest in bigger and better things. motor comes with all wiring loom uncut and still attached to the motor, turbo and manifold pretty much only needs cooler piping and a few nuts and bolts, has a tt racing heater hose kit installed also. Manual 180sx box with around78000ks + flywheel (needs machining). Motor and box for 1300ono. Have an auto ecu to go with this kit that will still work. all loom is included still attached to the engine, starter, alternator coilpacks ignitor cas air flow meter etc.
will not seperate or part out this package!
Also have other bits i can throw in that will help with the conversion (for datsun 120y and or 1600/510).
Maddat datsun 1600/510 crossmember and 1600 engine mounts/brackets to suit the ca18 $300
Carter black Lift pump with surgetank $150
S13 auto dash cluster $50
R31 28spline non lsd diff (no axles or brakes) $50
Custom driveshaft to suit ca18 to datsun bw68 borg warner diff for 120y $150
All parts located paradise point gold coast. Will not deliver. Pm or txt for more details and or pics if needed.
or just take all of it for $2000
please go here for pictures: or txt me on 0423501430 if you require a pic or info on a specific part.
http://www.gumtree.com.au/s-ad/paradi ... -1600-120y-kit/1026208726
Posted on: 2013/8/22 10:32
Re: ca18det and manual box datsun 1600/120y kit
bump
Posted on: 2013/8/23 23:20
bump need this gone! shoot me an offer and i will consider it!
Posted on: 2013/8/26 7:40
bump, throw me an offer on the motor and box. needs to go!
Posted on: 2013/8/27 8:14
From rutherford
id give ya 500 for the motor and box assy but im in nsw
Posted on: 2013/8/27 11:18
Quite a regular
From Gold Coast
seriously? your offering the guy $500 for a ca18det with box, ecu and full loom that he is asking onyly $1300 for? haha thats not cool! thats an engine conversion in itself!
Posted on: 2013/8/27 15:09
It's cool. After all he said "bump, throw me an offer on the motor and box. needs to go!" Doubtful the seller is so sensitive that he'll take it as an afront. He can ignore the offer, or if it's the best offer he's had he might actually take it.
Posted on: 2013/8/27 19:12
yeah i did say throw me an offer, but unfortunately $500 is way too low. so no to that one. cheers.
Posted on: 2013/8/27 19:55
Quite a regular
From Gold Coast
I know but its just common respect to actually make a reasonable offer instead of less then half the asking price yeah?
Posted on: 2013/8/27 21:33
From rutherford
da_fonz I think your being more annoying by commenting on a post when your not actually interested in buying it. I just stated my offer as I still would have to get it here
Posted on: 2013/8/27 22:12
