Ute lowering questions
From Mordialloc Victoria 3195
Firstly - Can anyone tell me how much does spring flipping, as per the tech wiki method, lower the rear end by?
Secondly - Any major problem just cutting the front spring to lower it by 50mm?
I've got a longer spare set from the 200B struts I fitted that I could try with.
The end result I'm after is the ute to be level, so the back will need to come down 70-75mm
If this is not enough i'll go with getting them reset somewhere in Melbourne
Cheers David
Posted on: 2013/9/3 10:55
Re: Ute lowering questions
Get about 2 inches almost from flipping.
Get Gemini fronts or 200b rear springs if chopping but they wont be captive with out shorter shocks.
Good luck.
Posted on: 2013/9/3 14:13
If your going to lower the front 50mm your going to bottom the shock out on big bumps so just be carful of that! The same with rear shocks 70~75mm is a lot of travel reduced to shock
My 2 cents!
Coilovers and shorter struts/shocks in front and shorter rear shocks and reset leafs is better as well just depends on your budget
:) cheers nick
Posted on: 2013/9/3 14:24
Car free
Thanks for the replies.
limited shock travel is ok but not being captive on full suspension droop was my worry. Will look for the shorter strut option.
Cheers D
Posted on: 2013/9/6 6:08
keep it simple
Quite a regular
I was quoted $340 to get reset and lowered anyone got done in Brisbane? were and how much?
Posted on: 2013/9/8 3:40
Quite a regular
From brisbane
I have stanza struts in my ute i used kdfl57 king springs removed bottom spring plate took 100mm of top off strut used r32 shocks 100mm shorter and put back together works great. in brisbane try main spring works on abbotsford road albion they do great work, stanza struts removed girlock calipers used c20 vanette ventilated rotors and c20 vanette calipers trx bluebird rear discs 7/8 master cyl 120y booster nearly pulls one g under brakes no brake bias valve my 2 cents
Posted on: 2013/9/9 13:17
From Gold Coast Queensland, Australia
What was the $damage for the pro suspension setup at main springs if ya don't mind me asking andrew1200?
Posted on: 2013/9/9 22:22
