120y fuel sender wiring
From Melbourne,Australia
Well since switching back to petrol Ive been driving around without a fuel gauge and figure I should probably do something about it before I start cruising more Ive fitted a standard 120y tank and sender back in and the factory wiring is still there so just wondering if anyone knows the wire color for the sender? Or has a wiring diagram for it?
Posted on: 2013/11/20 3:30
Re: 120y fuel sender wiring
Becareful with e85. Make sure your float is compatible as it can eat away some floats making them useless.
Posted on: 2013/11/20 3:46
Hmmm better look into that it's just a standard 120y sender so cant remember if the float is brass or plastic
Posted on: 2013/11/20 4:01
Stanza was brass
Posted on: 2013/11/20 4:22
120Y coupe
There is a single Yellow wire on the sender. It goes forward to the dash Fuel Gauge. The sender is grounded through the tank body.
Posted on: 2013/11/20 5:33
Looks like alternative stanza onei have. Can you just bend the arns to get them reading more accurate
Posted on: 2013/11/20 5:43
Thanks dd I got it sorted last weekend
Posted on: 2013/11/29 2:41
And its still working even in a why
Posted on: 2013/11/29 7:08
