Need Lowering Block Width for 120Y
Not too shy to talk
From Seattle, WA
Does anyone know the width of the rear axle of a 120Y? I don't have access to the car right now and want to order blocks. Thanks!
Posted on: 2013/11/20 17:16
Late-'75 120Y Coupe, '72 Nova 388 Stroker
Re: Need Lowering Block Width for 120Y
All B210s have leaf springs the same width as the 1200 (50 mm). So width of blocks is the same. But the pin and hole sizes are different (some blocks have enough meat to hog out the hole to correct size/location).
B210 uses isoclamp to mount the leaf packs, so slightly wider blocks will fit too
Posted on: 2013/11/20 19:15
