« 1 (2)
Re: N15 PULSER RADIATOR
Can anyone else shed some light on this. Its easy to find an N14 radiator but not so easy to find hoses that fit A series
Posted on: 2013/12/7 20:44
See our club article Radiator Upgrades
How to install Pulsar N14/15 radiator (Spacers, hoses info etc)
Radiator Upgrades
Posted on: 2013/12/8 8:43
I cut and shut hoses to fit with temp gauge adaptors in top and bottom hoses.
If the hose is a tight fit. 5 or 10sec in microwave works a charm. Just wear a insulated glove
Posted on: 2013/12/8 8:49
Radiator Upgrades
Thanks DD but no mention of hoses to use unless i missed it. Read it a few times already.
Posted on: 2013/12/8 16:25
The article has links to other pages. If you click " How to install Pulsar N14/15 radiator (Spacers, hoses info etc)" it says A15 standard bottom hose and for the top a 120Y bottom hose cut in half.
Posted on: 2013/12/8 17:54
Is it correct to assume the 120y lower radiator hose and B210 lower radiator hose are the same?
Thanks DD
Posted on: 2013/12/8 20:17
A 120Y is a B210. But B210 hoses may differ by year or market. YMMV.
Posted on: 2013/12/8 20:45
Two questions:
First:
Did the A-series have two types of lower radiator hoses? My A14 looks like this one:
There is a long metal tube coming off the engine block and a smaller metal tube that splits off of it. Am I correct in assuming the smaller metal tube (that splits off) is for the heater hose?
So do I require the solid length lower radiator hose?
I notice there are a split type here:
Second:
Can anyone confirm these are the hoses to buy for N15 Pulsar radiator upgrade?
A-series lower hose (one piece?):
21503-H1000 HOSE-RADIATOR
B210 lower hose:
21503-H7220
http://www.ebay.com/itm/Datsun-B210-1 ... a1be&vxp=mtr#ht_835wt_867
Posted on: 2013/12/31 21:51
Bump. Can anyone shed some more light on this? At least my first question? Thanks.
Posted on: 2014/1/19 3:48
« 1 (2)
