Browsing this Thread:
1 Anonymous Users
Wanted bluebird,r31,r32 speedo sender |
Not too shy to talk
From Brisbane
I'm after a bluebird or r31,r32 speedo sender must be mechanical. Putting into a ca18 gear box
Posted on: 2014/3/16 10:28
Re: Wanted bluebird,r31,r32 speedo sender |
Registered Users Contentmaster Usermaster
Sender? You mean speedometer gear. Any 71C gear will work to replace am S13/S14 sender.
Remove the sender and fit a cable drive in its place. Speedometer pinion & sleeve. Nissan part numbet 32703-N9019 is for Navara 19T.
You can also use a 71B pinion assembly by modifying the bolt tab. Basically most 5-speeds 1978-1985.
Posted on: 2014/3/16 16:17
Not too shy to talk
From Brisbane
Thanks mate.
Posted on: 2014/3/18 9:03
