« 1 (2)
Re: Is my tailshaft too long ????
Ive been busy but I see ivan took control of the pist and gripped the shaft with both hand and gave it a wriggle.
I cant believe nige didnt beat me to it but I guess hes busy beating hard wood
Posted on: 2014/3/19 10:18
From Bendigo, Victoria
I think you need to edit ^^^^^or learn to spell Mik.
Posted on: 2014/3/19 10:32
> I've been quoted $190.00 to shorten and balance at a driveshaft specialist. Does that sound about right?
Yes. They will build a new unit. It cannot actually be shortened because the tube is tapered.
Posted on: 2014/3/19 18:50
Thats not true dd. A professional can shorten them as I had done on mine for the 1200. It was tapered too. Thanks for deleting the post too. I love ford forum where almost anything goes
Posted on: 2014/3/19 19:48
From brisbane
Thanks for your help guys. Don't know why it won't fit cos like I said I've used this setup before but I guess know I've just got to fix it . unfortunately my usual method of "buy a bigger hammer" won't work !!
Posted on: 2014/3/19 22:49
A15 1200 ute, 77 mini -b16a honda vtec project
I shorten mine in my shop and they're fine! I do install a hoop though.
Some people find it easier to mod the engine mounts than to cut shut and balance the tail shaft.
If you have a fitter and turner friend, a slab is a good swap for a cut and shut.
Posted on: 2014/3/20 1:10
« 1 (2)
