Engine down
I have an A15 and it was running perfectly then it started running rough then died. It has spark fuel and air. The vacuum advance does not seem to be working. I used my mouth to try to create a suction but couldnt. It's the only thing I can find wrong. If its bad would it cause it to not start. I have fuel injected.
Gene
Posted on: 2014/4/1 2:28
Re: Engine down
Disconnect the hose from the distributor and plug it. It will run OK when plugged, but is a vacuum leak otherwise.
Sound like a water droplet has gotten into the carb
Drain the fuel bowl and see if it starts up. Only takes 5 minutes to try.
Posted on: 2014/4/1 5:42
Re: Engine down
Did you ever figure out the intermittent "underwater" sound of your A15?
Posted on: 2014/4/1 5:48
Re: Engine down
Yes it was the computer. Wen it got hot it would not work properly. I moved it. It is fuel injected so I don't have a carb. I wish I did then I could get rid of the computer which is its biggest problem. Started it this morning and warmed it up runs great. I shut it off and it won't start.
Gene
Posted on: 2014/4/1 14:04
Re: Engine down
Can you upload some pictures of your engine setup?
Regards,
Chris
Posted on: 2014/4/1 19:43
Re: Engine down
The map sensor even though it was working was somehow preventing the coil from sending a ground to the injector and working. New sensor and it is fixed
Gene
Posted on: 2014/4/1 19:48
