After market brake master
From Narellan,Sydney
What aftermarket brake master have people bolted up fairly easy? Without running a booster tho.anything match the 1200 firewall in the wilwood range? Also I'm running ford xr8 brakes up front and r31 rears.so think I may need something with a decent size bore.Thanks
Posted on: 2014/4/11 3:26
All stainless steel-mild steel Sheetmetal and tube work
All types of welding
Custom metal polishing
BSA custom fabrication 0415 904 474
Re: After market brake master
Thinking about using one of these anyone used 1 before?
http://www.wilwood.com/MasterCylinder ... andem%20Master%20Cylinder
Posted on: 2014/4/11 3:38
From Central coast NSW
Won't the size of ur caliper pistons dictate what size ur master has to be?
Posted on: 2014/4/11 6:42
Yeah it will I need around a 1" bore.but I'm talking about what sort of master have people already used
Posted on: 2014/4/11 7:37
I have a 7/8 master in mine
Posted on: 2014/4/11 8:22
Car free
Without a booster nick? What brand is yours and did it mount up ok?
Posted on: 2014/4/11 9:04
From BlueMountains NSW
I found the guys at specalist brake and clutch Penrith very helpful and willing to think outside the box without charging an arm and a leg .cheers Baz
Posted on: 2014/4/12 12:37
I DON'T LIVE IN THE PAST....I JUST TAKE DAY TRIPS
