Radiator question
From Nyngan, nsw Australia
can you blokes tell me are the CA18det and SR20det mounting points the same?...
Posted on: 2014/5/8 9:26
living is good,.....
Re: Radiator question
From my experience yes, just hose locations differ. Mine have been aftermarket radiators
Posted on: 2014/5/8 11:21
i just had alookc a few pics, yeah all i could see was hose relocation, i have a CA wanting to swap to SR rad
Posted on: 2014/5/8 11:56
I had a CA radiator at the start of my build but changed to an SR one as top hose inlet is on passenger side so gets the hose away from the intercooler piping going to the throttle body.
The mounting points are all the same as long as it's an S13 radiator as the S14 one is taller.
Your probably already aware that you then use an EXA thermostat housing which will point in the right direction for the SR top inlet.
Posted on: 2014/5/8 13:58
SR one has top hose inlet is on passenger side so gets the hose away from the intercooler piping going to the throttle body.
EXACTLY MY POINT!!
Posted on: 2014/5/8 14:07
