Arp l20 main studs?
From socal, USA
I was reading the wiki and it says L series main studs fit the a12. So I order a arp kit from ebay part number 202-5401. My problem is 3 of the studs are longer than the others and will not tighten on the caps. Do you guys think this is a mix up or are 3 of the l20 studs longer?
Posted on: 2014/5/11 0:37
Re: Arp l20 main studs?
The A-series uses the same 10 bolts (not studs) that the L-series engine does including L20B and Z24 and KA24E.
The Nissan one are PLENTY strong.
See Nissan Part Number 12293-18001
http://www.nissanpartszone.com/parts/ ... main-brg~12293-18001.html
ARP stud kits:
L-series ARP 202-5401
A-series ARP 202-5401a
Posted on: 2014/5/11 4:26
From socal, USA
so then the L20 stud kit has 3 longer studs? how can the the bolts be the same and the studs not?
Posted on: 2014/5/11 9:20
