What size thread is this port on the exhaust manifold?
From SoCal
Another weird question but I am so close to finishing this A15 swap into my midget. I have the same exhaust manifold as pictured below. I would like to plug the large threaded hole, the same one that has a pipe in the picture below. Anyone know what thread the hole is?
Posted on: 2014/5/11 0:00
1969 MG Midget, A15/60A
Re: What size thread is this port on the exhaust manifold?
From SoCal
Oh, the EGR wiki page sez:
Exhaust Manifold has larger EGR port, otherwise is same as 1976. Larger EGR Tube to manifold BPT valve added USA Exhaust Manifold EGR Tube inner diameter 11.8mm (8mm 1976)Manifold boss dia.: 32mm (25mm 1976)Thread size: M22 (M16 1976)
M26 x ?? What sort of plug should I use? Or should I just have it welded shut?
Posted on: 2014/5/11 0:43
Hi,
I have seen these either welded shut, braise welded shut or the tube crimped shut and the pipe cut off after the crimp.
I wouldn't go through the hassle of fitting a plug as it is difficult to remove (not always) the existing. It would look much neater with a plug though.
Posted on: 2014/5/11 1:31
Use an M22 or M16 metric bolt from your local hardware store.
Posted on: 2014/5/11 4:45
From SoCal
Found a M22-1.5 flanged plug at Autozone. Needa 652886. Juuuuust a bit too long so I installed it with permanent thread lock and hard Permatex under the head.
Posted on: 2014/5/11 20:10
