« 1 (2)
Re: A12 Twin dellorto too much?
twin hitachis ... would I get similiar performance out of these carbs to the dellortos?
No. But more power at high RPM than the stock carb.
Posted on: 2014/6/3 22:41
From Cairns
But how much better would the dellortos be? would it be worth the extra $1000 or would i be better of putting that money somewhere else?
Posted on: 2014/6/4 9:13
Edited by formo88 on 2014/6/4 21:21:05
Looks far better than twin SUs
Quads: $1000
Twins: $700
definitely worth it.
Posted on: 2014/6/4 22:19
From Cairns
alright thats what i was hoping you would say. thanks for all your input
Posted on: 2014/6/5 21:28
From Cairns
Hey guys I managed to pick up a second hand set of dellorto carbs today. but the manifold is oval port and has gx cast on the top. So i need a new manifold. will a weber manifold fit these dellortos or is the flange different?
http://www.ebay.com.au/itm/NEW-INLET- ... ories&hash=item233c3b7f3c
the link above is for a manifold that i found on ebay but it is for 2 webers. I just want to know if my dellortos will work with this.
thanks
Posted on: 2014/6/22 11:56
From New zealand
Yes, Webber and Dellorto carbs will go on the same manifold. Your round port head will not match the oval port manifold though. You should be able to purchase one easy enough. Go to www.palmside.co.nz in Christchurch. They have the round port manifolds. If not let me know and I will dig one out of the shed.
Posted on: 2014/6/22 12:52
From Cairns
Hey just an update
the motor has been stripped and the block is being machined, cam and lifters are at crow cams, I even managed to pick up a closed chamber h89 head so all is going well. my only drama now is getting a 2 inch exhaust for the car, I already have a set of extractors. Is there a company that would have something made up or am i going to have to get it custom made by an exhaust shop?
Posted on: 2014/7/25 23:31
« 1 (2)
