diff centers
From New zealand
Hi
Wondering if a h190 centers would fit into a h165 diff housing ? I know the h165 is an 8 bolt an the h190 is a 10 bolt .... can it fit with modafication ? If so will you have to change the axles as well ?
In a datsun 1200 ute 89
Thanks
Posted on: 2014/6/9 3:31
Re: diff centers
No. The H190 is 190mm in diameter. Too big to fit in the H165 housing.
Posted on: 2014/6/9 3:41
Re: diff centers
From New zealand
Ok cool.... id need the whole diff then ! Would it need to shortend to fit a 1200 ute ?
Posted on: 2014/6/9 3:48
Re: diff centers
Not necessarily! Depends on how wide the one you get is. For example H190 rear axle assembly from Datsun 320 is narrower than a 1200.
Posted on: 2014/6/9 4:13
Re: diff centers
From New zealand
Sweet thanks for the info !
Posted on: 2014/6/9 5:50
