question about PRI-SLOW jet and Autoline carbs
From Connecticut, USA
I recently rebuilt a 1982 Hitachi carb for my 210 and the mixture screw has no effect. I can turn it all the way in or even remove it completely with little change. I blocked all the vacuum ports and still no change with the mixture screw. This is the 4th Hitachi that I've rebuilt and had no problem with the others, though this one had lots of extra stuff being an 82'. I noticed that when I was installing the jets(which I soaked in a small jar) that the pri-slow jet never bottomed out and tightened. It was one of the jets with a screw covering it. Are they both suppose to tighten? I don't remember this problem with the others. Also has anyone gotten a carb from Autoline? I found one on rockauto.com and was considering getting it.
Thanks for any info.
It's nice to be a member again. I was over 10 years ago, but hadn't signed in for about 8-10 years. So I re-registered.
Posted on: 2014/6/6 0:39
Re: question about PRI-SLOW jet and Autoline carbs
The 1981-1982 carburetor is a Hitachi DCR306, the main changes are vacuum secondary and vented fuel bowl.
Yes, they are both supposed to tighten. Perhaps the threads are stripped out.
Posted on: 2014/6/6 0:47
Thanks for the response. The threads seemed good as the jet kept lowering and lowering. It will bottom out and tighten, but it seems to be much lower when it does tighten. (I'm sorry I wasn't clear in the 1st post)I shouldn't have said that "never bottomed out and tightened". It seems to be further in the hole then the other jet, and I don't remember it being that low. So I set the jet at the same depth as the other and didn't tighten it. It probably will go 4 or 5 turns more before bottoming out and tightening.
Do you think this would make the mixture screw ineffective?
I never was able to see if the mixture screw worked before I rebuilt it because it was covered with a plug that I removed when rebuilding it.
Posted on: 2014/6/6 1:31
Yes, it needs to be tight.
Posted on: 2014/6/6 1:54
From Sydney Australia
Blocked idle passage somewhere, Quick fix is to swap 1 and 4 plug leads over and rev it while backfiring as that reverse explosion often clears a blockage without a carb rebuild.
The problem is the small hitachis have very small passages that do block up this often works to unblock them
Posted on: 2014/6/9 1:15
I took apart the carb and tightened the jet. This time when I tried it I couldn't get it to idle unless I cranked up the idle high. I had another carb that was known to be good( a 1979 one),but had similar results with that one as well. After the original problem I eliminated all the emissions stuff, plugged all the ports etc. So after going crazy looking for vacuum leaks, and finding nothing, I finally found the problem.
The 1981-1982 210 has a vacuum switch which is connected to the fuel shut off solenoid. I disconnected it when I eliminated the emissions stuff. My other 210s never had this. So I reconnected it, and it runs great. I was able to get it to idle smooth at 600rpms. I wanted to make sure I posted a follow up on what fixed it. The original problem was the jet not being it all the way , and the second problem with the idle was due to the vacuum switch effecting the fuel solenoid.
Thanks for all the help.
Posted on: 2014/6/10 4:52
What is this vacuum switch?
MPG 210s have extra stuff on them.
Posted on: 2014/6/10 5:51
The 81' and 82' 210s have a vacuum switch that has 3 leads and 1 vacuum port. Also this car has the A15-S engine which might be different. The fuel solenoid is connected to the switch and can't get power without it connected. I think all the older 1200/210 fuel solenoids are connected directly to the ignition switch.
Posted on: 2014/6/11 3:01
Some, but not most 1980-1982 have the Fuel Shut-Off System which sounds like your description.
Is yours an MPG version? This means 5-speed 210s with FU in the VIN.
Posted on: 2014/6/11 3:50
No, this car is a 1982 210 with automatic trans. There is a CU in the VIN. I also have a 1981 210 Deluxe which has the same engine(A15-S) with a 5-speed. It might be considered a MPG version. I have to check the VIN. It has every option that was available being a deluxe. 5-speed, air conditioning, sun roof, tinted windows and a light in the glove box. The problem is that the doors are rusted bad and I've never been able to find door skins.
I was going to ask what the difference is between the A15 and the A15-S ?, but perhaps I'll ask in a new post
Posted on: 2014/6/12 4:51
