fuel pump oil leak
Need some advice please I have a datsun 1200 motor that I have fitted a new mechanical pump to. I replaced the plastic spacer between the pump and engine. I used gaskets as well as sealant, but there is still oil seeping through. I tried tightening more, but the spacer broke and I had to get another one. Tried adding more gasket, but that also hasnt worked. Anyone else had this issue? Thanks in advance
Posted on: 2014/6/20 8:09
Re: fuel pump oil leak
Yes. If the internal seal is bad, replacing the fuel pump will fix it.
Posted on: 2014/6/20 8:15
Not really. Are you letting the sealant cure before trying to test for leaks?
Most 3bonds etc are 24hour cure times for full curing
Posted on: 2014/6/20 8:16
No, I didnt let it cure for that long. Maybe that is the issue?
Posted on: 2014/6/20 15:08
Not sure could be. There is a relief valve for fuel from the mechanical pumps just make sure its not that.
With a new pump unlikely
Posted on: 2014/6/20 22:18
Probably not relevant but I had an issue here:
Diaphragm Breather
Posted on: 2014/6/21 22:40
