(1) 2 3 4 ... 8 »
mikuni bike carb help needed
Restoration of missing topic
posted by unfamilia on 5/15 4:43 GMT
well bike carbs on and runs. Just need to sort accel cable and also carb 2 us leaking from air hole on the left as above. Fuel builds up and dribbles out there and overflow at idle. Under revs its fine.
Im unsure what hole is for but must be linked to float bowl. Raised fuel float and it dribbled less but unsure what it is before I adjust much more.
They are mikunis off a zr750 or 1000.
Started up almost straight away once I sprayed dome start ya bstard in at first lol.
Any bike carb folk know???
Posted on: 2014/6/27 9:21
Re: mikuni bike carb help needed
posted by benny on 5/15 5:29 GMT
fuel pressure reg, as most bike fuel tanks feed carbs via gravity. Your fuel pressure is probably to high at idle
posted by unfamilia on 5/15 7:07 GMT
Im using that fuel pressure reg I got off you benny. Its set at lowest. All other carbs fine except that 1 carb? Might check needle and seat.
Got diy cable done now
Posted on: 2014/6/27 9:22
posted by ddgonzal on 5/15 7:26 GMT
Didn't the ZR750 come with Kiehins? Those look like mikuni BST flat slides.
In any case, put a vacuum/pressure gauge on the fuel line and ensure its 2 psi. Many regulators won't go that low. And yes clean the fuel inlet needle/seat.
posted by D on 5/15 9:30 GMT
Looks good but alot of dust debri on that close up of the slide
make sure you keep them clean to avoid sticking
How does it sound? should be rorty!
Posted on: 2014/6/27 9:23
posted by clyons8 on 5/15 10:05 GMT
What you talkin' bout? It's a bit oily and quite hairy. A bit like Mik.
Mik, put a tap on the fuel line to restrict the fuel. Regs don't work that low. You need the fuel available. I used a small tap from an old bike and planned to snip the spring in the facet pump but never needed to.
The pump never ruptured the diaphragms.
posted by clyons8 on 5/15 10:08 GMT
There you have it. Oil, slides and ruptures all in one thread!
Get your Greek out Mikonopolous!
Posted on: 2014/6/27 9:24
posted by unfamilia on 5/15 10:36 GMT
So just a restrictor tap on the fuel line hey.
I was worried might be a cracked float. They are those plastic floats.
posted by LittleFireyOne on 5/15 10:43 GMT
could you run them off a mechanical pump? would make it super simple when I put mine on.
Posted on: 2014/6/27 9:25
posted by unfamilia on 5/15 10:49 GMT
You can but need to drop the pressure to 2psi max usually
(1) 2 3 4 ... 8 »
