nissan a12 engine ?
Quite a regular
hi all, I have a Nissan A12 engine I think it came out of a sunny the engine number is 550810A the reason I ask is I like to put a electronic distributor on but do I put a early one on or it does make any different which one I use as long its a A12 thankyou
Posted on: 2014/7/5 11:19
Re: nissan a12 engine ?
From Kelmscott Western Australia
Put a e15 dizzy in it put the A series gear on it weld a tab on the hold down bracket and changecoil
Been in the ute in 2 yr and hasent missed a bit
Posted on: 2014/7/5 11:24
71 Datsun 1200 ute with A14 fuel injection and T50
59 Morris minor ute with A15 fuel injected with intercooled turbo
Quite a regular
there are one on eBay for late A series Nissan for $99 dollars would this be ok regards warren
Posted on: 2014/7/5 11:57
I got no idea about the ebay ones
But heres my electric dizzy out of a n12 pulsar E15
jpg  20140627_171535.jpg (126.64 KB)
13822_53b7dc80ef925.jpg 392X294 px
Posted on: 2014/7/5 12:08
Quite a regular
would any one know about the one's on ebay
Posted on: 2014/7/5 12:26
No welding is needed. Only if you put an early distributor on a late engine is that.kind of fabrication required.
Early A12: 1970-1973
Late A12: 1974-1994
The E15 distributor is easy to modify to fit an A12 and has stock reliability.
You can weld a tab, or use a non-weld method like this:
E15 distributor swap
Posted on: 2014/7/5 20:43
