« 1 (2) 3 4 »
Re: a14 gx motor Perth ONLY
From Kelmscott Western Australia
Mates not intreasted
Posted on: 2014/7/5 7:01
71 Datsun 1200 ute with A14 fuel injection and T50
59 Morris minor ute with A15 fuel injected with intercooled turbo
Bump
Posted on: 2014/7/6 1:13
Up to the top
Posted on: 2014/7/6 23:39
Re: a14 gx motor Perth ONLY UPDATED PHOTOS
If you still dont believe its a A14gx engine then well something must be wrong
jpg  20140708_163608.jpg (114.23 KB)
13822_53bbbe3068b06.jpg 392X294 px
jpg  20140708_163617.jpg (105.98 KB)
13822_53bbbe3fcdcd1.jpg 392X294 px
jpg  20140708_163545.jpg (75.30 KB)
13822_53bbbe4ddeec3.jpg 392X294 px
jpg  20140708_163554.jpg (124.72 KB)
13822_53bbbe5cc96ec.jpg 392X294 px
Posted on: 2014/7/8 10:49
Sitting with its 5 brothers which are gx a14s
Posted on: 2014/7/8 10:51
Up to the top
Posted on: 2014/7/9 0:11
What numbers are embossed on the cylinder head top?
Posted on: 2014/7/9 3:34
H75 301
Posted on: 2014/7/9 5:50
Exactly, you can tell because it is a small regular oval port with no water galleys at the manifold face.
Attached is a picture of what a real GX head looks like. This is a New Old Stock unit. See the writing on the top? No numbers.
You need to stop the misinformation, whoever is telling you that it is an A14GX engine has no idea what they are talking about. You have an A14T engine, far from an A12GX.
jpg  image.jpg (44.98 KB)
7952_53bcd46347eb6.jpg 506X284 px
Posted on: 2014/7/9 6:37
This engine is not a GX because:
- It is an A14 and the A12GX was an A12.
- It hasn't got the twin outlet exhaust manifold and is fitted with the A14T exhaust manifold (regular manifold).
- It does not have the big port GX Head, it is fitted with a big port gasket but you can see the small oval ports if you look carefully. There are also no visible water galleys.
- It is not fitted with GX carburettors, it is fitted with A14T carbs which has a four stud manifold flange and tri bolt pattern on the air cleaner side. The inlet manifold also has the two elongated mounts on the front foremost carburettor mount.
- The carburettors feature an auto choke and emissions gear which came on the A14T
- The distributor is mounted midway which further clarifies the engine having no GX-era relevance.
I understand that you see two hitachi carburettors and decidedly claim the engine as a GX series but that's not how it works.
You will also find that the twin Hitachis that you have fitted are also found on the L-series engines which makes them worth next to nothing without the manifold.
Posted on: 2014/7/9 6:45
« 1 (2) 3 4 »
