Turbo A-Series, Anyone running a GT17 Garrett?
Just wanting to know if this fitting on the turbo cast iron housing is a common feature on these turbo's.
I understand it is a mount but it is nuisance! It fouls with the strut tower on a 1200.
Posted on: 2014/8/4 21:48
Re: Turbo A-Series, Anyone running a GT17 Garrett?
From melbourne
Quite often turbo housings have tabs cast and tapped into them for factory heat shield's to bolt too, you can cut them down/off just make sure you blend all the sharp edges so not to cause cracks from stress raiser from heat cycles witin the cast iron housing.
hacksaw or small stainless cutting disc with a sanding disc to blend will do the job ;)
Posted on: 2014/8/4 23:22
Edited by anths on 2014/8/4 23:59:25
E85 Turbo 120y wagon Built not bought........
Hi Anths, thanks for the advice and detail. Having a look at what's around it appears it isn't a common feature. I'll either modify the manifold or the housing.
Thanks again.
Chris
Posted on: 2014/8/5 9:12
I ended up modifying the manifold.
Posted on: 2014/8/6 9:10
From melbourne
great work mate I would still cut down the casting on the housing ;)
Posted on: 2014/8/6 10:07
