« 1 (2) 3 4 »
Re: maddat steering box brace
From Creswell, Oregon USA
I make a billet LHD and RHD brace for the 1200
Posted on: 2014/8/28 6:47
An idea doesn't work unless you do.
Instagram @MD_Machine
Parler @MDMachine
Thread resurrection!
I'll bite. How much?
Posted on: 2014/8/28 7:13
From WA perth
ha matt if you going to make those billet i'll have one
Posted on: 2014/8/28 10:17
I can't beat the price of Maddat's stainless brace, but I can get these in at $125.00 USD.
wheel side brace plate not shown but it's part of the setup.
Posted on: 2014/8/28 12:07
Parler @MDMachine
From WA perth
when you get one made I like to see what you done to the top.I know u will use high grade ali to keep the thickness down to a min so it dosn't look to chucky
Posted on: 2014/8/28 13:50
What benefits would this give you over the maddat item?
I'm assuming it would be slightly stiffer, but would it be a noticeable improvement over maddat's to justify the extra bit of cash?
Posted on: 2014/8/28 21:43
"What benefits would this give you over the maddat item?
I'm assuming it would be slightly stiffer, but would it be a noticeable improvement over maddat's to justify the extra bit of cash?"
Its just based on what people want to buy. Go with a Stainless Maddat one or buy a billet aluminum one. Both items would work as what they are intended. Options are available and it just comes down to preference.
Matt D.
Posted on: 2014/8/28 23:31
Parler @MDMachine
Ok, thanks for the reply Matt
Posted on: 2014/8/28 23:57
I bought a maddat one and it doesn't fit well. Theres a 10mm gap up against the sidewall
Posted on: 2014/8/29 7:06
I saw that as an issue so the holes are slotted slightly for adjustment, but 10mm is in need of a sandwich shim.
Posted on: 2014/8/29 17:52
Parler @MDMachine
« 1 (2) 3 4 »
