350Z and G35 - 6 speed transmission
From Creswell, Oregon USA
Anyone try to mate these to our A series?
I'm looking at how small the the bell housing is on these gear boxes.
For $300.00 it might be worth the effort to adapt..
Matt D.
Posted on: 2014/9/11 17:48
Re: 350Z and G35 - 6 speed transmission
An adapter plate can be fabricated.
A challenge is the sheer size. An automatic transmission Tunnel can be used.
Here is the super 350Z gearbox compare to the big Toyoda W55 box:
Notice the shifter. Another puzzle to solve.
Posted on: 2014/9/11 20:16
Thank you for the side by side. W55 is the same size as the T50?
I have the capability to make the adapter. A new tunnel is obviously a must on the car for that 350 box.
The length of the snout presents quite the problem. I could shorten the linkage but still would only half the extra length it has. Hmmmmmmm maybe a reversed elbow on the stick sending it forward vs reverse and put the EM brake in front vs behind .....
Posted on: 2014/9/11 21:46
An idea doesn't work unless you do.
Instagram @MD_Machine
Parler @MDMachine
