coupe dash swap rev gauge light? help
Rev gauge lights dont work?
Posted on: 2014/10/16 1:47
Edited by bobby_sr20 on 2014/10/23 8:55:21
Edited by bobby_sr20 on 2014/10/23 8:56:09
Re: sedan to coupe dash swap help
From Perth WA AUS
Kind of sounds like a bad earth connection, check and clean all earth connections (including rear tail light earth)
Or could be wiring harness main plug to back of dash, the wiring does differ in some models.
Posted on: 2014/10/16 8:16
Datsun 1200 2Dr sedan.
Yes - common problem. Sedan rectangle and round dash use the same connector, but the wiring differs.
PROBLEM: indicator globes stay on
See Dash Changes for Sedan
Posted on: 2014/10/21 21:21
Yeh I figured it out. Bad earth at rear tail lights.
Cheers
Posted on: 2014/10/22 5:32
One more thing fellas. My rev gauge lights dont come on at all any ideas?
Rev gauge is hooked up and works etc earths all done
Posted on: 2014/10/23 8:54
Re: coupe dash swap rev gauge light? help
Any ideas? The bulbs might be burned out? Another idea is that the lighting power wire has a bad connection where it attaches to the speedometer.
Tachometer Wiring
Posted on: 2014/10/23 9:01
Ive put new bulbs. And havr just tested to see if there is power and there is on my voltage tester thing.
could it still be a earth problem???
Posted on: 2014/10/23 9:14
Fixed! The earth on the bulb holder was rusty lol. Cheers
Posted on: 2014/10/23 9:32
