Choosing Radiator for my a15t
Quite a regular
Hey guys.
Seeing if anyone can help me out in selecting the right radiator. My motor is currently getting build, I've got a a15t. J Ive read a lot about the n15 pular ones and alloy ones off ebay,but I am unsure which to go with. is it ok to stay with the standard Radiator in my coupe? do i need to modify the radiator support? do i need my make fixing for the radiator i choose?
any help would be appreciated
Sam
Posted on: 2014/11/26 10:23
Re: Choosing Radiator for my a15t
From Melbourne, Australia
definitely go bigger, will need custom mounts, will probably need to open up support panel for more air flor
N14 is massive but light and thin. They need a lot of radiator support cut to really utilize it and are a tight squeeze into the engine bay
If you can get your hands on a Toyota Paseo radiator they are a much nicer fit in terms of size and are a nice thick copper radiator. the hose fittings match a-series size and are on the correct sides. Minimal radiator support cutting is required if you want to get air flow to all of it. I run one on my rally car where we didnt want to cut the radiator support out and it runs cool enough to not need a fan at all the majority of the time, we just run a thermo up uphill stages or sitting at traffic
Posted on: 2014/11/27 0:12
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Quite a regular
thanks for that mate
Posted on: 2014/12/1 11:50
