Ute rear shocks - KONI part # ?
Just pricing whether I should buy KYB or KONI rear shocks.
I cannot find the KONI part # in the tech wiki, only KYB.
Anyone have this info?
Thanks.
Posted on: 2014/12/20 7:46
Re: Ute rear shocks - KONI part # ?
KYB is the original factory equipment.
KONI never made a ute shock, and no longer makes the sedan or coupe shocks. Some say the VW konis will fit the ute -- choice of standard or firm.
Posted on: 2014/12/20 9:16
From Las Vegas NV
I'm using rear shocks from a 71 dodge colt , fairly cheap and there are not stiff or too soft , and I didn't have to order
Posted on: 2014/12/21 5:53
That is interesting. They would be pretty cheap to buy in the US too?
Posted on: 2014/12/21 8:27
http://www.rockauto.com/catalog/moreinfo.php?pk=8443&cc=1080133
20.79 ea. Might be worth a try but to me they look longer than the 1200 shocks
Posted on: 2014/12/21 11:22
From Las Vegas NV
Yes, I got them at oreillys auto parts they cost me $12 each and at autozone I think they cost $19 each
Posted on: 2014/12/21 13:49
Hmmmm. Do i spend $130 for a set of KYB shocks to factory ute specifications or spend $40 on a pair of USA dodge colt specials?
The colt shocks are larger uncompressed than stock.
Might not work with my 2" reset lowered leaf springs.
Posted on: 2014/12/22 1:45
factory ute specs will ride the best. The gabriels are valved stiff to compensate for soft-sprung cars. Not good with performance-sprung suspension such as the factory ute.
Posted on: 2014/12/22 2:46
From Sydney Australia
Last time I fitted Koni shocks to a Ute I used VW Passat Station Wagon rears and they were from memory on the spec sheet damping wise pretty close to what was needed length was OK compressed and extended as well, They worked fine in a Ute fitted with a Z18 Turbo, The only issue was getting the turbo to load up properly (many Gearing changes later including input gears in the box it still needed cement bags in the back, Just not as many)
Posted on: 2015/1/2 11:21
What year Passat?
Posted on: 2015/1/4 0:33
